Dynatrace SaaS - Enhanced monitoring of a PostfgreSQL database that is on AWS RDS
fernando_albuqu
Organizer
Is it possible to have enhanced monitoring of a PostfgreSQL (https://www.dynatrace.com/support/help/technology-support/monitoring-support/how-do-i-set-up-enhanced-postgresql-monitoring/) database that is on AWS RDS? So one of the requirements in the documentation is to have OneAgent running on the host of this database.
PS: Dynatrace SaaS
Thank you,
Fernando.
pahofmann
I moved your question to the Dynatrace forum, as it seems to be about Dynatrace SaaS and not Dynatrace AppMon 🙂
Dynatrace Certified Master, AppMon Certified Master - Dynatrace Partner - 360Performance.net
michal_nalezin
Dynatrace Advisor
Dynatrace Advisor
We are providing such functionality for Oracle on RDS, but we are not actively working on expanding it to PostgreSQL.
