Steps to uninstall Dynatrace oneagent from Azure Service Fabric
aappiah
Contributor
I see there are step to install dynatrace oneagent on azure service fabric here:
https://www.dynatrace.com/support/help/cloud-platf...
What are the step to uninstall the oneagent from service fabric. Preferably one that utilizes powershell.
patrick_thurner
Dynatrace Pro
Dynatrace Pro
Hi Allan,
you can uninstall our vm-extension following this example (#1): https://docs.microsoft.com/en-us/powershell/module...
As extension name in the command "Remove-AzureRmVmssExtension"you need to apply "oneAgentWindows"
Patrick
Thank you.
