Does Agent need to be installed on Tomcat Front end host in order to see UI traffic?
michael_a_loizz
Newcomer
Does OneAgent need to be installed on Tomcat Front end host in order to see UI traffic?
nj_njoku
Inactive
Hi Michael,
If you are automatically injecting the JavaScript agent to your user's browsers from a particular process then yes the agent needs to be installed on the host that process is running on. In most cases, I have seen the Automatic JavaScript injection being setup on the frontend process like a webserver. So in your case unless you are doing the Automatic JavaScript injection via another process on a different host, you will need to install the agent on the frontend host. See more on JavaScript injection below
https://www.dynatrace.com/support/help/user-experi...
Hope This Helps
NJ
