Is excluded PurePaths when we enable "Exclude IP addresses from monitoring"?
kohei-saito
Helper
From "Application" > "Advanced settings" > "Exclude/Include IP addresses from monitoring", I can exclude specified IP addresses from monitoring.
To be more accurate, I think I can exclude them just from "Application" monitoring.
I'm sure that PurePaths associated with unmonitored IP addresses can be captured because the way of capturing of Applications metrics and that of Server-Side PurePaths are different from each other.
In addition, I think that this setting influences only Application so PurePath may be still captured.
Is my understanding correct?
Kohei
Philipp_Kastner
Dynatrace Pro
Dynatrace Pro
Hi @Kohei S., that's correct.
Kind regards, Philipp
