Web request naming rules for RUM?
muthukumar_peri
Advisor
Hi All,
I'm looking for web request naming rules for RUM data similar to what we have for server side.
Do we have this functionality for RUM data? Can someone help me on this please?
Regards
Muthu
sia_h
Dynatrace Pro
Dynatrace Pro
Hi Muthukumar,
Yes we're able to rename the User Actions in RUM. Go to Applications in the navigation of your Dynatrace environment and select the application that you're interested in renaming the user actions.
From there on go to the edit section of the application via the button in the top right corner of the application overview page. Then select User Actions in the sub navigation and you will be able to create and modify rules to rename user actions in RUM.
Sia
Thanks, Siavash.
