question
Ramses G. avatar image
Ramses G. asked ·
Error: Not enough space on /opt/dynatrace/oneagent. Required free space: 1000 MB in docker
When I try to install in docker I get this error:
11:00:13 Started agent deployment as a Docker container, PID 27637.
11:00:13 Downloading agent to /tmp/Dynatrace-OneAgent-Linux.sh via https://xxxxxx.live.dynatrace.com/api/v1/deployment/installer/agent/unix/default/latest?Api-Token=***&arch=x86&flavor=default
11:00:14 Download was skipped as the agent version did not change
11:00:14 Validating downloaded agent installer
11:00:15 Verification successful
11:00:15 Deploying to: /mnt/host_root
11:00:15 Starting installer...
11:00:18 Checking root privileges...
11:00:18 OK
11:00:18 Installation started, version 1.149.188.114613, build date: 31.07.2018, PID 27637.
11:00:18 Detected platform: LINUX arch: X86
11:00:18 Detected bitness: 64
11:00:18 Filesystem with /opt/dynatrace/oneagent is mounted under /opt
11:00:18 Error: Free space on filesystem with /opt/dynatrace/oneagent: 887 MiB
11:00:18 Error: Not enough space on /opt/dynatrace/oneagent. Required free space: 1000 MiB
oneagentinstallationdocker
1 Answer
Babar Q. avatar image
Babar Q. answered ·
Hello @Ramses G.
The following links have the information about the disk space requirements for OneAgent full-stack installation and updates and also the procedure.
https://www.dynatrace.com/support/help/installatio...
https://www.dynatrace.com/support/help/infrastruct...
Babar
Share
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services custom event alerts notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions diagnostic tools session replay permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
