Question on Dynatrace Managed RUm Manual Injection
tarun_agastya2
Inactive
We have added Dynatrace RUM agent through manual injection,But we are able to see the UEM data from there we are not able to drill down to server-side Purepath data.
Can someone help in understanding how the manula injection work for Dynatrace RUM.
Your case is similar to mine - I also saw only UEM data without server side.
In my case the Reason was:
The instrumented web server addressed on the app-server without agent.
The web server without agent addressed on the app-server with agent.
It doesn't depend on injecting type (automatic or manual)
Alexander
axel_ayala
Dynatrace Advisor
Dynatrace Advisor
HI Tarun
One of the downsides of deploying RUM manually is that the correlation of server side web requests is not possible.
