I need to be able to extract the which servers/jvms have alert threshold set up and on which metric
hceylan
Newcomer
I need to be able to extract the which servers/jvms have alert threshold set up and on which metric. Summary of alert threshold, I need to run this script to check every day. Any ideas if I can access this data via rest call or any other way?
ChadTurner
DynaMight Legend
DynaMight Legend
You can get this data via the Environment API V1 for Services, and Processes:
Let me know if you need a hand with this 🙂
-Chad
