Amazon Linux2 and Resin support
apm_license
Participant
Let me ask you a question.
Is there a roadmap for Amazon Linux2 or Resin support?
I confirmed OneAgent platform & capability support matrix, But I can't find out it.
Best regards,
Kohei Otsuka
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
Amazon Linux 2 is already supported. No plans for Resin from what I have heard.
https://www.dynatrace.com/support/help/technology-support/supported-technologies-and-versions/
However, you can think of using a remote plugin on that system that push data to Dynatrace
Senior Product Manager,
Dynatrace Managed expert
