Why do we need ActiveGate for Dynatrace?
hi All,
Can someone explain me why do we need Active Gate in Dynatrace unlike Appmon. Does it has any Pros and Cons . We are planning to move from Appmon to Dynatrace.
Sree
7 REPLIES 7
franz_soengen
Inactive
Hi Sree,
actually it's the other way around: the ActiveGate is an optional component for Dynatrace that acts sort of like the Collector acts in AppMon (which is mandatory). So it's main function is being a proxy for OneAgent traffic, compressing it and making it easier to import data from different networks where you would only need one firewall rule instead of one for every server. It also has other functions as you will find in the documentation: https://www.dynatrace.com/support/help/deploy-dyna...
As I said, ActiveGates are optional. You can directly send data from your OneAgents to your Dynatrace instance.
best regards
Franz
rastislav_danis
DynaMight Pro
DynaMight Pro
there is also functionality of dynatrace that requires activegate, f.e. monitoring of vmware, collecting of process memory dumps.
Alanata a.s.
Thanks Rastislav,
One query - In scenarios like Dynatrace on Cloud providers like AWS or Azure but not vmware in that case ?
/Sree
not 100% sure what you mean, but also if dynatrace is deployed in cloud/saas, activegate can be used to monitor vmware (it just need access to vcenter and proper account to do that)
Alanata a.s.
jason_knapp
Newcomer
The useful link Franz supplied no long exists and you are now displayed a page that no longer shows that break down.. I came back here to refresh my knowledge on that to find it less usefull now.
rodrigo_passos
Newcomer
Hi Sreedhar
ActiveGate
Environment
To perform data
compression before sending to Dynatrace Managed Node
To store memory
dumps
To integrate
with VMware and run remote plugins
ActiveGate
Cluster
For
implementations with external data: synthetic testing, mobile app monitoring,
Davis integration,
Best regards
Rodrigo Passos
chuck_scott
Newcomer
when why does the documentation lead me to BELIEVE that I must have it?
