If the host has more than 32GB RAM will we be needing more than 1 one agent to be installed on that host. Please clarify.
Answer by Muthukumar P. ·
Hi Rangapriya,
Not required. Please note there will be only 1 oneagent per host irrespective of your RAM size and RAM will define the license and it is calculated in terms of host units. 8 GB will be considered as 1 host units.
Hope this helps!
Muthu
Hi Muthu,
Ok, I think I have confused between the licenses and the number of agents. Thanks for the clarity.
Rangapriya
DECEMBER 12, 10:00 AM GMT / 2:00 PM ET
Learn how Dynatrace Real User Monitoring automatically detects errors that impact your end users caused by erroneous 3rd party or CDNs.
December 10, 4:00 pm CET / 10:00 am ET
Register here
Register here
Register here
You cannot use "--unregister" option during upgrade. 1 Answer
Can i change default OneAgent log directory on installation\working? 2 Answers
DT Managed: Proxy Error While Installing Second Cluster Node 2 Answers
Docker not starting after install OneAgent 2 Answers
Apigee API Gateway as a Proxy between Managed Cluster and Mission Control 1 Answer
