Merging the unique docker container services running on the same host
srinivas_krish1
Newcomer
Hello All,
I have situation where my application is running as a docker container. There are 3 containers running from the same image due to which the process name is same and the service name is also same. All these 3 containers running on the same host. Due to which dynatrace is detecting this services as 3 different services with same name.
leterally i have the sercie listed out under transactions and services as shown below.
abcservice - process1
abcservice - process 1
xyzservice - process 1
abcservice is from one image and the xyzservice is from another image however the process type is same. However I can regroup these 2 sets into 2 different process groups. however I want to merge these 3 services as 1 as all are doing same fucntions , with same technology etc. I see this option of merging is there if these services are running on 2 different hosts. But I want to know if there is any option to merge these services which are running on the same host.
Thanks and Regards
Srini
nj_njoku
Inactive
Hi Srinivas,
As long as these services are running on processes that are not in the same Process group, I do not believe it is possible to merge them. See more on the criteria for merging services here
NJ
