how to filter with not in request.
Aamir_khan
Participant
While creating Multi dimensional analysis chart or basically applying filter anywhere is there any way to apply filter with 'not' as I cant find only filter as "request: name contain" and nothing with a not
6 REPLIES 6
nj_njoku
Inactive
Hi Aamir,
This feature is not available in the product presently. Please submit an RFE for this.
NJ
mattias_wessman
Newcomer
Did you post a RFE for this? If yes I will upvote 🙂
ChadTurner
DynaMight Legend
DynaMight Legend
As stated this is not available in Dynatrace at this time. There has been RFE's in for it along with multiple filtering such as "Show me hosts Shutdown and hosts Offline" alogn with the other side of that coin "Show me hosts that are NOT Available"
-Chad
AntonioSousa
I have just upvoted and commented the RFE below. Despite being for charts, the idea is the same. Does anyone know of other RFEs that might be related?
https://community.dynatrace.com/spaces/483/dynatrace-product-ideas/idea/230150/exclude-rather-than-i...
Antonio Sousa
Gerardo_Campos
Newcomer
Hi I think it would be very useful something like this RFE. In particular, I am hitting with a criteria that throws me some results that include what I am looking for, but I need to do like a "difference" in set theory, like my_goal = A - B, where A is the result set I am getting but I need to subtract those results in B, and I don´t find a way to do this. Thanks!
Hello @Gerardo_Campos
Metric expressions enable you to use simple arithmetic operations right in the metric selector.
https://www.dynatrace.com/support/help/dynatrace-api/environment-api/metric-v2/metric-expressions/
Babar
