HTTP Monitor - Total Downtime
lukas_lutz
Newcomer
The outage duration and total downtime is changed if the duration of the timeframe changes.
So if the actual outage is 15min it is shown as 1 hour in the 7 days timeframe and as 12h in the 30day timeframe.
The Availability calculation is correct but it is confusing.
anyone knows the reason for that and if this will be fixed?
JamesKitson
Dynatrace Guru
Dynatrace Guru
If there are multiple outages in a longer window wouldn't it make sense for those values to be larger? What is confusing about the availability - it should just be successful runs / total runs?
Also keep in mind this feature has still only just entered the beta phase so of course any issues discovered will be fixed.
James
