What is the difference between security gateway and activegateway on Dynatrace managed ?
Hello, I was trying to install activegateway by following the steps described in the documentation.
But instead of finding the activegateway on the home page [...], I found add new security gateway.
I would like to know the difference between activegateway and security gateway.
Best regards,
3 REPLIES 3
nkobayashi1
Helper
Hi Bouare,
It seems that ActiveGate is former Security Gateway.
We have tried both of ActiveGate and SecurityGateway, it must be the same component. I think that the name will be changed in next releases. But it has not been posted on the release notes, as far as I know.
Thanks, Noah
Correct. The name is changed in v1.151, release notes should be published soon.
Keep calm and build Community!
Thanks Noah
