host units usage
michael_thiry
Participant
Hi ,
We want to calculate the host units usage for each environments, because our customers ask us a pay per use billing.
The Number of days host units used for the month by customer
Is it possible to export this information , in a dashboard or maybe in the agent log ?,
ty
Joe_Hoffman
Dynatrace Leader
Dynatrace Leader
In the upper right corner of your GUI, select the "Dude" icon, and select Account Settings. Under this menu you should be able to see consumption by Environment.
For Managed you can get anoverview of consumption per environemnt in the Cluster Management Console.
p.s. The "dude" icon is the best description I heated thus far ;D
Dynatrace Certified Master, AppMon Certified Master - Dynatrace Partner - 360Performance.net
