.net Process group seperation
tom_taborovski
Newcomer
Hi.
We want to separate our process group by environment (.net process).
We tried to configure the 'Process group detection' with environment variable and still the no separation occurred.
Did any one tried to separate .net process by environment (Dev\QA\Prod\...)
Also I want to added that the host group is the same (And we want it that way) across all environments.
Tom.
3 REPLIES 3
Julius_Loman
DynaMight Legend
DynaMight Legend
Just a stupid question - did you restart those processes? Process separation works at process startup time.
Host group (as far as I know) must be specified at installation time and cannot be changed.
tom_taborovski
Newcomer
Yes we did restart the machine after the set up.
and the Host Group was set correctly
Did you verify the process has those environment properties set? Using process explorer for example.
