How to add the count of SQL requests in the purepaths list page ?
jean_blanc
Newcomer
I want to check if slow purepaths is related to high SQL requests count. But no count is available on PurePaths list page.
ChadTurner
DynaMight Legend
DynaMight Legend
I dont think this is possible form the Purepath page - you can submit a RFE for this and it might even be possible to create a multidimensional analysis chart that shows this. Otherwise you will need to use two tiles on your dashboard to show the metrics you are looking for.
-Chad
