Under Rule based request attributes I get an error " Missing permissions to create or edit request attributes"?
rudra_sparky
Newcomer
Under Rule based request attributes I get an error " Missing permissions to create or edit request attributes" even after enabling 'User Management and Group Management'
franz_soengen
Inactive
Hi Rudra,
you posted in the Dynatrace Forum but tagged your post with AppMon, which product is this about? As the permissions sound like Dynatrace my answer is for the latter.
You'll need to be a member of the predefined "Confidential data admin" group to configure request-data capture rules or be a member of any other group with the "Configure request capture data" permission given for the environment you want to configure:
You can find more information about permissions in the documentation: https://www.dynatrace.com/support/help/shortlink/u...
best regards
Franz
