Quartz transaction monitoring
gautier_begin
Advisor
Can we monitor Quartz transactions in Dynatrace the same way as in AppMon:
https://community.dynatrace.com/questions/94960/is-there-a-way-to-have-dynatrace-monitor-tasks-kic.h...
Which configuration ?
chris_geebelen
Dynatrace Mentor
Dynatrace Mentor
Hi Gautier,
You can define a customer service with an entrypoint of your quartz job:
See link below on how to setup a custom service.
https://www.dynatrace.com/support/help/server-side...
The Appmon equivalent is a sensor on a purepath with status "Active and start Purepath".
Kind regards,
Chris
