ActiveGate with Proxy Installation Error
john_liebal1
Contributor
2018-09-19 13:52:31 UTC
SEVERE [<*******>] [MessageBroker] Failed to send
INITIAL_COLLECTOR_SETUP message (target-type=SERVER, target-id=-1000),
uri=https://******.live.dynatrace.com:443/communication -
CommunicationException: HTTP communication failed, status code=407,
reason=authenticationrequired
Command is:
sudo /bin/sh
Dynatrace-ActiveGate-Linux-x86-1.151.217.sh PROXY=********** USER=dynatrace INSTALL=/app TEMP=/app/tmp LOG=/app/logs/dynatrace
CONFIG=/app/conf/dynatrace/gateway
Is there something we are missing here?
6 REPLIES 6
JamesKitson
Dynatrace Guru
Dynatrace Guru
I bet that's your proxy asking for authentication:
https://www.dynatrace.com/support/help/deploy-dyna...
James
john_liebal1
Contributor
I thought that could be the case, the error does seem to indicate that the authentication is needed at Dynatrace.
alexander_schub
Newcomer
Hi We are facing a similar issue when installing Activegate-Linux with PROXY parameter. Our proxy does not require authentication. Any hints how to resolve the problem appreciated.
Alex
teoderico_david
Participant
Has anyone successfully setup the Activegate-Linux with PROXY parameter? We are having the same issue? I appreciate if you can share how you resolved the issue.
Did you try to use the standard URL format for the proxy parameter? The https://username:password@proxy:port
Or export this variable prior to installation?
I think the gateway will install event without connectivity to cluster and you can specify the proxy parameters in config file afterwards.
teoderico_david
Participant
Julius, thanks for your respond. We are not using uid/pwd in our proxy and what we are trying to achieve is to do SSL Interception. I have set the URL, Port and Proxy-scheme to https. I have also imported the certificate to the custom keystore but we are getting SSL handshake error.
