RUM - Apdex rating "unkown?"
sergio_maurenzi
Inactive
Hi, I have an issue regarding the user sessions Apdex rating at RUM.
Since a week ago, I noticed some user actions of all users had a value of "Unknown?" as the state of Apdex rating, instead of "Satisfied / Tolerated / Frustrated".
It only happens with one of the application, I compared the configuration settings between two applications and I have found no differences.
The only thing I could probe is that these user sessions have not "visual complete" data.
It's the first time I see that and I don't how to change it!
Please, could you help me?
3 REPLIES 3
nj_njoku
Inactive
Hi Sergio,
If Visually Complete is the key performance metric selected for this application in Application Settings -> General, can you confirm if Visually Complete is enabled in the Application Settings -> Content Capture. If it is enabled and you still do not see Visually Complete data, you may need to use a different metric as your key performance metric e.g. user action duration.
NJ
sergio_maurenzi
Inactive
Thank you NJ!
I confirm you that the key metric selected is Visually Complete for both settings at General and Content Capture.
I'll try with other key performance metric.
Thanks again!
sergio_maurenzi
Inactive
Hi NJ!
I changed the key performance metrics for this app and now it is working.
Basically, I configured, Load actions with 'HTML downloaded' and XHR actions with 'user action duration'.
Thank you!
