How to know in which hosts of a PG exceptions are ocurring?
antonio_villarr
Advisor
We are doing a POC in an environment where the
services of an application are located in a Process group of 9 jboss
servers. When analyzing exceptions, customer asks us if there is a way
to know which one of those servers are the ones generating those
exceptions? Because we always end up in a view like this:
Thanks in advance.
Antonio V.
JamesKitson
Dynatrace Guru
Dynatrace Guru
Starting at the service level you can add a filter for that specific exception and then drill into the Service Flow diagram and set it into the infrastructure mode (in the top right). This will show you which hosts on which services the transaction with the exceptions flowed through. You could also start at the diagnostics -> exceptions analysis view or by drilling into an individual PurePath from the screen you posted (though the latter will only be for that one PurePath instead of all that may have the exception across the service):
James
Thank you very much.
Antonio V.
