Dynatrace Web Chart set static scale
Don_Meuth
Organizer
We have a chart that measures WebLogic Hogging Threads, and usually the range is between 0 and 4, but when an even occurs with the dynamic scaling it appears that a jump to 8 is a very large jump. I need it to be more consistent. is there any way in a custom chart to set the left side scale to 20? if not can I have it at least always show the Alerting threshold? setting the scale a a static count is preferred, but the threshold display would probably work
david_n
Inactive
Hello Don,
I don't think there is a way to manually set the scaling for a custom chart right now. It must make a good RFE though. You can post it the idea to the forums and see if more people want similar functionality in Dynatrace.
David Nicholls
