dynatrace api External Synthetic Tests - return 403
Yosi_Neuman
Hi guys
Trying to run: curl -X POST "https://xxxxxxx.live.dynatrace.com/api/v1/synthetic/ext/tests?Api-Token=yyyyyyy" -H "accept: application/json; charset=utf-8" -H "Content-Type: application/json; charset=utf-8" -d "{ \"syntheticEngineName\": \"HarelRobo1\", \"messageTimestamp\": 1539426879000, \"locations\": [ { \"id\": \"1\", \"name\": \"1st type test\" } ], \"tests\": [ { \"id\": \"1\", \"title\": \"first test\", \"description\": \"testing if its works\", \"testSetup\": \"no setup\", \"expirationTimestamp\": 1539426879000, \"drilldownLink\": \"string\", \"editLink\": \"string\", \"enabled\": true, \"deleted\": false, \"locations\": [ { \"id\": \"string\", \"enabled\": true } ], \"steps\": [ { \"id\": 0, \"title\": \"string\" } ], \"noDataTimeout\": 0, \"scheduleIntervalInSeconds\": 0 } ], \"testResults\": [ { \"id\": \"1\", \"totalStepCount\": 1, \"locationResults\": [ { \"id\": \"1\", \"startTimestamp\": 1539426879000, \"success\": true, \"responseTimeMillis\": 234, \"stepResults\": [ { \"id\": 1, \"startTimestamp\": 1539426879000, \"responseTimeMillis\": 456, \"error\": { \"message\": \"string\", \"code\": 0 } } ], \"successRate\": 0 } ] } ]}"
returns:
{"error":{"code":403,"message":"Token is missing required scope. Use one of: ExternalSyntheticIntegration"}}
While all the switch's for this token are on
Any explanation what are we doing wrong here? is it because this API is in EAP?
Yos @Gil Givati
4 REPLIES 4
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
Yes that's because this API is in EAP stage right now. Please request to take part in that EAP and we will enable that feature flag for your environment, which will then also show the additional token scopes that are necessary.
Yosi_Neuman
Hi Wolfgang,
Thanks for the answer.
Where can we apply for this one ?
Yos
Hi @Yos N., can you please send me an email philipp.kastner@dynatrace.com
tarun_agastya2
Inactive
Hi @Philipp K
We have a requirement to send external synthetic tests into dynatrace. Can you please let us know how can we succeed in sending data to dynatrace for all the synthetic tests .
