Auto-Instrumentation iOS Mobile App
chuan_sern_wong
Advisor
I am supporting a PoC with the developers to instrument the Dynatrace OneAgent into iOS native apps
The developers had configured the require setting as document in the Dynatrace Help - cocoapods; also reference to youtube video https://www.youtube.com/watch?v=PV5IbndM54k; and verify with Dynatrace One that the setup was correct.
However, data is not showing on the application dashboard. Hope any kind soul could help the steps to troubleshoot.
Many Thanks
5 REPLIES 5
Patrick_H
Dynatrace Champion
Dynatrace Champion
Sorry with this little information it is hard to guess why no data is showing up.
• what is the configuration the customer used?
• what doe the iOS agent log say?
• which environment is this so we can take a look at it?
to not share all this stuff publically here I would recommend to open a Support Ticket
iOS help: https://www.dynatrace.com/support/help/shortlink/ios-hub
Ok sure, how do one access to iOS agent log and where does it located ? I will log a support case.
Patrick_H
Dynatrace Champion
Dynatrace Champion
Log is only available when run from Xcode - see Dynatrace Help for the required settings: https://www.dynatrace.com/support/help/deploy-dyn...
Did you follow the agent setup walkthroug after creating a mobile Application in the Dynatrace webUI?
Just want to update, the issue was resolve by the Dynatrace Presale who provision tenant.
chuan_sern_wong
Advisor
Hi Patrick,
As I am not the developer, the developer did provide the necessary screenshots that had shown he had done the require steps accordingly based on Cocoapods instrumentation i.e adding the applicationId and etc extracted from Dynatrace SaaS webUi paste in the info.plist and also pod Dynatrace in pod file.
As mention, the developer did use the livechat to verify and livechat support didn't find anything not right in his configuration.
I had log a support case - https://support.dynatrace.com/supportportal/browse/SUP-15045
