Hiding Application/Service?
bbaratono
Contributor
Is there a way to hide an application or Service from being monitored. For example in our Middleware JVMs we run multiple apps. One of the apps is a health checker and we want DynaTrace to ignore it, based on URI would be great...
Is this possible?
JamesKitson
Dynatrace Guru
Dynatrace Guru
If you just want to exclude the health checks you can either 'mute' them or exclude them altogether from being captured in the service settings -> deep monitoring section:
Worked, thank you!
