Can we replace Dynatrace with other monitoring solutions like AppDynamics for Unbreakable Pipeline?
surendra_bysani
Participant
Can we replace dynatrace with other monitoring solutions like AppDynamics for Unbreakable Pipeline? is there any Dynatrace component that creates a mandate to use Dynatrace One/Dynatrace Plugins only?
andreas_grabner
Dynatrace Guru
Dynatrace Guru
Hi. This is like buying the body of a Ferrari and putting an old engine of a Kia in there 🙂
Joke aside. The Unbreakable Pipeline is a concept that "in theory" can be implemented with other tools. Just wondering though why you want to use a tool that hasnt been built for that type of integration. If I would be you - and if you want to be successful - I would go with Dynatrace 🙂
Contact our DevRel team through devrel@dynatrace.com
