question
Prashant S. avatar image
Prashant S. asked ·
HTML 500 Error in Jetty after enabling UEM
Anybody come across the use case where Jetty application getting HTML 500 error as soon as UEM is enabled .
Dynatrace Managed
1 Answer
Chad T. avatar image
Chad T. answered ·
@Prashant S. Are you still encountering this issue? Did it get worked out? If so did you need to reach out to support? What did you discover as it relates to working towards a solution on this?
Share
