what is oneagent managed maximum log retention period
osman_ozdemir
Newcomer
Can we have one agent managed local log retention to infinite? as long as storage is available keep the logs?
ctturner
Inactive
@Osman O.
Basic Dynatrace log analytics allows you to analyze 2GBs of log data from a 7 day period (as long as the file is still present on the host) If you would like to capture and retain log files in your managed environment for an extended period of time, you would need to upgrade to Log Analytics Premium for those restrictions to be removed.
osman_ozdemir
Newcomer
thanks, excuse me for I have not defined my question in better detail. My interest was about Dynatrace server audit logs, but from the previous answer, I can safely say that it is safe to say server audit logs are infinitely kept as long as storage available. for application logs, in the event of log analytics premium and storage available again infinitely...
