How do I fix loading agent in nginx ingress in kubernetes?
william_qualls
Newcomer
Kubernetes 1.8.4
Latest OneAgent installed
nginx 1.13.5
Navigate to Hosts | host_name | Process | nginx_process_name | Properties and tags
"this process must be restarted..... to gain full visibility...."
I restarted the Pod hosting nginx. After nginx came back in a new Pod, the view showed "Activation of deep monitoring was unsuccessful. Monitoring of statically linked Go programs that do not load libc is not supported."
skrystosik
Did you checked if your nginx version is supported now by oneagent? https://www.dynatrace.com/support/help/shortlink/nginx-binaries#list-of-supported-nginx-binaries
Regards, Sebastian
The NGINX process of the official ingress-nginx controller container image cannot be instrumented automatically. You have to do the following:
https://www.dynatrace.com/support/help/shortlink/ingress-nginx-k8s#instrument-kubernetes-ingress-ngi...
Restart the pod after the edition of configmap file
