question
Andre V. avatar image
Andre V. asked ·
Mobile application monitoring traffic via Cloudflare
Has anyone implemented iOS or Android mobile app monitoring successfully in Managed, where Cloudflare is used along the application delivery chain?
We've configured a Cluster ActiveGate, Cloudflare and the relevant firewall rules but when we run the endpoint test via CMC, all tests fail. Traffic flow would be: device -> Cloudflare -> F5 -> Cluster AG.
If we change the setup to bypass Cloudflare, the connection tests succeeds, leading us to believe the issue lies with Cloudflare, but we don't know what or why. Any suggestions would be welcome.
Also, I assume the test is run from Mission Control? Is there any specific traffic that has to be allowed which is sent back to MC or once successfully deployed, to the mobile device?
configurationDynatrace Managedmobile monitoringandroidioscmc
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
Did you checked steps from this article? https://www.dynatrace.com/support/help/deploy-dyna...
Are you sure that port is opened?
1 comment Share
I have yes, port 9999 is open on Cluster AG, but it seems like it gets dropped on the Cloudflare level so I was hoping someone in the community have set it up like this before.
Cloudflare only allows certain ports, as per their documentation, but logically it should still work if set up like this: user -> 443 -> Cloudflare (443 is acceptable port) -> 443 -> F5 -> 9999 -> Cluster AG
Is there any logging which will show the requests hitting the AG? We suspect the request gets to the AG, but Cloudflare adds headers which confuses AG and therefore the tests fail.
0 Likes 0 · ·
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions session replay diagnostic tools permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
