Analyze slow JS delivery of nginx
I could need some help in finding out why our nginx sometimes needs ages for delivering java script files.
Unfortunately Dynatrace
only comes up with the response time but no hint what the problem could be.
Is there a way to track down the problem further with dynatrace?
regards,
Gerald
4 REPLIES 4
skrystosik
In purepath there is no clue about it? It always looks like on screen?
Regards, Sebastian
HI @sebastian k.,
Thank you for the quick reply 😉
Unfortunately the PP isn't that helpful either
How look nginx performance metrics from time when such situation showed up? Reasons can be different, from problem with accessing file on storage until problems with nginx performance itself (or host). How often you see such timings?
Regards, Sebastian
Sorry for the late reply.
Well it happens from time to time:
The nginx and host metrics for me look kinda normal. What exactly would you like to see?
