how to verify custom time series data put to dynatrace via Timeseries APIs
phile
Newcomer
Hi, I just have json data and put to Dynatrace server via Timeseries APIs at https://nww98385.live.dynatrace.com/api-doc/index.... the status 200 success returned and I found my data is in list, but I'm not sure if this data is correct or using somewhere else. Could you have a link to an UI or something like that which can shows that data.
Phile
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
Best is to either custom chart it on your dashboard or you use search on host level in smartscape to find your custom device name and click on it to jump to the custom device dashboard screen.best
Wolfgang
