question
Raju P. avatar image
Raju P. asked ·
how can we instrument dynatrace for .net thick client (like desktop exe application )
Dear All,
how can we configure and monitor the .net thick application(desktop application using dynatrace.
What type of agent can be used ?(.net Agent or oneagent SDK)
What type of challenges we will face during instrumentation?
Will dynatrace capture the all the actions which we perform on thick client application?
is there any coding needs to be implemented?
Please do provide your pointers if you are implemented
configurationRUMtags and metadatadotnetuser actions
1 Answer
Dominik P. avatar image
Dominik P. answered ·
You can use OpenKit for .NET to monitor the user experience of thick clients. For more info please look here: https://github.com/Dynatrace/openkit-dotnet
You can also find an overview in our online help:
https://www.dynatrace.com/support/help/deploy-dyna...
Best regards,
Dominik
Share
