question
Dave H. avatar image
Dave H. asked ·
Dynatrace Managed Proxy Setting
I have an installed Managed Cluster, connecting successfully to Mission Control. I have my proxy setting configured in the Internet Settings, but this only displays the actual proxy hostname. Is it possible to retrieve the account used to authenticate the proxy? Also does this proxy setting also apply to the integration options; such as Slack, or is it exclusively for Mission Control?
Dynatrace Managedadministrationmission control
1 Answer
Julius L. avatar image
Julius L. answered ·
Normally you should see the username for the proxy configuration in the CMC. If it's empty, then the username is not used (proxy allows anonymous access).
For individual proxy settings (your second question), you can configure different settings in cluster.properties. See here for details. If you do not configure anything in the config file, then the values entered in CMC will apply also to webhook integrations.
Share
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services custom event alerts notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions session replay diagnostic tools permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
