Oneagent is uninstalled after rebooting host
atim
Newcomer
Hi
I recently add our host to be monitored with dynatrace. After I deploy agent to my host, it said that I should restart the processes in order to be fully visibility monitored. Then I reboot the host, after that the host is not monitored. It is said that "Host is not monitored. OneAgent uninstalled 1 hour 51 minutes ago."
How could this happen?
5 REPLIES 5
radek_jasinski
Did you install the agent on root privileges?
Best,
Radek
Have a nice day!
Yes indeed, i installed agent with root user
What is the operating system? Windows, Linux, ...?
Do you have the right communication ports open?
Is there no mechanism for undoing changes on the system after restarting the application?
Could you share agent log?
R.
Have a nice day!
At 99% there is a mechanism for undoing changes on the machine, as I wrote earlier.
Have a nice day!
Julius_Loman
DynaMight Legend
DynaMight Legend
If oneagent files and systemd unity (or SysV init script) are not there after reboot then your host does some reverting mechanisms such as reverting filesystem changes on reboot to a snapshot.
