REST endpoints for license usage of Dynatrace OneAgent?
krunal_dave1
Helper
Are there REST endpoints for license usage available?
4 REPLIES 4
skrystosik
According to my knowledge about Dynatrace SDK it's not possible to write such plugin. Plugins are related to different level of data than such thing. If I understand you properly you need rest endpoints about license usage?
Regards, Sebastian
krunal_dave1
Helper
Hi Sebastian, Thanks for quick response. I apologies about explaining problem statement at first, Yes I'm looking for rest endpoints for license usage of dynatrace oneagent.
Krunal
adam_gardner
Dynatrace Champion
Dynatrace Champion
Hi Krunal, have a look at the /entity/infrastructure/hosts endpoint. Calls to this endpoint result in a JSON containing host info. One of the JSON values is: "consumedHostUnits": 1
@ Adam - thanks for prompt reply.
Yes we did figured out yesterday about the /entity/infrastructure/hosts endpoint, and now we are able to calculate used license.
Krunal
