Is there a way we can export list of discovered services in dynatrace
rohit_sharma
Guide
Is there a way we can export list of discovered services in dynatrace. I am looking for a list of all the services discovered on dynatrace
Radu
Dynatrace Champion
Dynatrace Champion
Hi Rohit,
I would look into the Dynatrace API (Topology, Services endpoint) for your use case.
More docs on it are here: https://www.dynatrace.com/support/help/dynatrace-a...
Best regards,
Radu
Thanks Radu
