Filter out keep alive web requests
tarjei_utnes
Organizer
We have an application we have instrumented in Dynatrace Managed. This application sends keepalives (HTTP GET request to an ASMX endpoint) at regular intervals. This pretty much makes the user sessions useless, as it creates a lot of noise in the user sessions view.
Any good ideas on how to avoid this? Filter it out from the user sessions or otherwise?
JamesKitson
Dynatrace Guru
Dynatrace Guru
Check out the responses here. If there's a reason you can't do what is described there you can also mute them as described here.
James
