About the association between UserSession and UserAction extracted by User Session Query language API
menda
Guide
I'm experimenting with the User Session Query language API.
The document contains "userActions" in the UserSession object, but the execution result of the Dynatrace Environment API doesn't include it.
[Document URL]https://www.dynatrace.com/support/help/dynatrace-api/environment/usql-api/#anchor_table
[Query]select * from Usersession
I could extract only UserAction with API, but I couldn't find a key to link UserSession and UserAction.
[Query]select * from useraction
I intend to extract UserSession and UserAction individually with User Session Query language API.
Is there a way to associate those data?
Best Regards,
Masahiko Enda
Julius_Loman
DynaMight Legend
DynaMight Legend
As far as I remember, you can directly select it this way:
select userid,userSessionId,useraction.* from usersession
