Would Root-Cause be shown if it lies in another management zone?
Imagine an environment where there are management zone A and management zone B, if a problem in zone A is due to the CPU or Memory Saturation of an entity in management zone B, would the management zone A's user accounts able to read the root-cause in the problem details?
sia_h
Dynatrace Pro
Dynatrace Pro
Hi Wai,
You'd still be able to see the full end-to-end view of the problem. However, you will not have the ability to analyze the details of entities in Management Zones you have no access to. You can read more in the blog post.
Sia
