Question about the difference in data amount between OneAgent and AppMonAgent
Hi all,
I got a question from my customer about the difference in data amount between OneAgent and AppMonAgent.
I understand that OneAgent has more data than AppMonAgent.
Is my understanding correct?
And if you know, would you tell me how much the data amount will increase?
e.g.) +50% increase etc.
ChadTurner
DynaMight Legend
DynaMight Legend
Okay so basically Appmon is designed for a particular technology and/or application layer whereas a single OneAgent per host is required to collect all relevant monitoring data of supported technologies.
Here is blog post talking about upgrading.
https://www.dynatrace.com/news/blog/its-time-to-upgrade-appmon-to-dynatrace-now/
Here is some documentation about some of the features of dynatrace there is some overlap, but mostly just dynatrace features
https://www.dynatrace.com/support/help/shortlink/intro
-Chad
