Dynatrace SaaS: user auto expiration process
rohit_sharma
Guide
I am looking for the process of auto-expiration (if any) of a user created in dynatrace SaaS.
For Instance if a user was created on dynatrace by a company mail id (joe@companyname.co.na), and the user now left the company:
1) Will the user be automatically be removed from the users list
2) If not, will he still have access with old company id to Dynatrace SaaS ?
3) Would a manual audit be required everytime ?
4) Any process regarding this available in documentation ?
Regards
Rohit Sharma
4 REPLIES 4
skrystosik
I don't know any option to autoexpire users in dynatrace SaaS. For now it's early access program for SAML in SaaS so maybe this is option for you.
Regards, Sebastian
gerald_
Dynatrace Pro
Dynatrace Pro
We do not have such an auto-delete process in place. As soon as we have SAML federation ready, you can set it up for your domain. Thus, the user won't be able to login to Dynatrace after the user was deleted from your identity provider.
Gerald
Thanks for the update Gerald, I believe it would be GA in Q1 2019 ?
Regards
Rohit Sharma
Right, March/April timeframe.
