How to track which user session took how much time?
sangeetha_mitta
Organizer
Please help on the below requirement?
I tried application flow with my id – it took 10 mins for transaction to complete
Customer tried same application flow with his id – it took 8mins for the same transaction to complete
We can view both requests with purepaths and also response times 8 min and 10 min in oneagent.
But requirement here is to know which user session took how much time either 8 or 10 mins..
Internally we know 10 mins is with my id and 8mins is with his id. This info need to be shown in oneagent tool as well..
Please help on the above
pahofmann
You see the backend requests to the services with 8min and 10min response time, but they are not linked to a user action, if you look a backtrace from there? Or are you not able to find your user session at all?
Dynatrace Certified Master, AppMon Certified Master - Dynatrace Partner - 360Performance.net
ChadTurner
DynaMight Legend
DynaMight Legend
What you can do is set a tag event for that application so it will tag your user sessions with your names. From there you can use the User Session query language to filter out and list the users with the highest response time.
-Chad
