Cluster ActiveGate routing web traffic to a specific CLuster ActiveGate when doing Agentless with code injection
michael_taylor
Dynatrace Advisor
Dynatrace Advisor
Hi All
Is there a way to route traffic from Pre-Porduction to a specific cluster active gate when doing Agentless injection (manually). So the idea is that in pre-production they send the data to a specific cluster activeGate and In production they send to another cluster activegate.
Mike
tom_lichti
Participant
Thanks Mike for creating this, you've pretty much nailed the request, I'm guessing that there is nothing we can do from a Dynatrace perspective, it would have to be setup externally with dedicated endpoints defined to split the prod and non-prod beacon signals, but I'm open to hearing other options.
fstekelenburg
DynaMight Pro
DynaMight Pro
An old thread, but I think DNS or modified javascript injection may do the trick?
Kind regards, Frans Stekelenburg                 Certified Dynatrace Associate | measure.works, Dynatrace Partner
