Difference between Process Group & Kubernetes[app] while filtering services in customchart?
rashmi_2_gupta
Inactive
While creating custom chart for metric JVM Thread Count, when I am filtering out services, I can either chose the process group (included all processes) or use Kubernetes[app] and then select that microservice name (which has that one process group). What is the difference?
While chosing the latter, I see more thread count for same number of processes.
I am trying to understand the kubernetes metrics here and how is it different from selecting the process group of that same kubernetes[app].
skrystosik
Hello Rashmi, do you see separate process group for each Kubernetes app? If it's not equal you should consider process group detection rules:
https://www.dynatrace.com/support/help/monitor/pro...
Regards, Sebastian
