Can we disable Slowest 10% and auto-detected baseline email alerts
I have enabled custom alerting for the services on Dynatrace OneAgent. And defined alerting custom alerts as below threshold.
I am getting frequent alert (flood) for Slowest 10% response time alert and auto-detected baseline alert because of AI engine.
Can I disable alerts for Slowest 10% response time alert and different auto-detected baseline alert(and is it advisable)
Thanks!
skrystosik
There is no such option, you can set there high threshold. Your setting is not working using AI but as a static threshold, this is why you have huge amount of alerts on 10% slowest. Make it higher if you want to use static thresholds for general usage
Regards, Sebastian
