Can a mobile application built on React Native framework be monitored by Dynatrace OneAgent Managed?
rs00478708
Participant
Hi Support,
We have a mobile application that uses React Native framework for for the components. The file extensions are .jsx. There are few pages that are non-script based(like static ones) using the web based. I believe the Native SDK for android and IOS needs to be used for manually instrumenting the application. Please clarify and confirm if the we have Native SDK API s for supporting React Native framework.
Rangapriya.
4 REPLIES 4
Patrick_H
Dynatrace Champion
Dynatrace Champion
React Native currently is not supported but on the Roadmap. You can read more about it on this thread: https://community.dynatrace.com/spaces/482/dynatrace-open-qa/questions/198832/need-info-on-how-to-in...
iOS help: https://www.dynatrace.com/support/help/shortlink/ios-hub
rs00478708
Participant
Ok, I got to see this thread already and was just checking if there was some positive progress on this.
Thanks , let me request Kin.K for the plugin he had tried.
Rangapriya.
Do you have any news of the roadmap to monitor React native ?
Ludovic
Community Team
Community Team
Instrument mobile app with Dynatrace React Native plugin
If you have any questions about the Community, you can contact me at maciej.neumann@dynatrace.com
