Can we add custom thresholds for different log events based on time ?
rohit_sharma
Guide
Can we add custom thresholds for different log events based on time and not based upon counter.
example: alert when 'error' text entry in log every 30 minutes and not like every 1 time it occurs
Regards
Rohit Sharma
3 REPLIES 3
skrystosik
Hello
for now this settings are the only one we have:
So you can be alerted when condition of event frequency will be fulfilled.
Regards, Sebastian
Thanks for the response Sebastian, Is there any way we can change this frequency from per minute to like per 30 min or 60 minute as an example ?
ex: instead of 5/min to 5/30 min
Unfortunately not. If it is important for you to have such option please post RFE (product idea). If you will collect more votes dynatrace may consider such option.
Regards, Sebastian
